Sony BDVEF200 - Strange HD Sound issue
profile.country.en_GB.title
TehFuzz
Visitor
Hi guys, I'm hoping someone can help me wiht the issue I've been having, as it's driving me up the wall!
Just before Christmas I bought myself the Sony BDVEF200 home cinema system, to give myself a nice upgrade to the lacklustre sound performance from my Samsung LE40D503.  If it's relevant at all, I get my cable TV service from Virgin Media, and am currently using one of their HD Tivo boxes.
All hooked up in the usual way, tivo box goes into one of the Sony unit's HDMI inputs, and then the Sony output to a HDMI slot on the TV.  Fantastic.
All is well and good when playing DVD's and BluRay's, the sound is fantastic.  Same goes for any regular non-HD channels through the tivo box.
The problem occurs on numerous (I'm yet to try them all) HD channels however.  When I first switch to any of said HD channels, everything seems to be normal.  The sound works perfectly, all is good.  The oddity occurs when whatever programme I'm watching goes to a commercial break.... the sound cuts out completely!  Changing channels on the TiVo box does nothing, the sound remains muted on all channels from this point onwards, and the only resolution I'm left with is to turn the Sony unit off completely and back on again, at which point the sound springs back to life.  It's also worth note that if I simply leave the box switched on, and wait for the commercial break to end, the sound does not come back.
To make things even more strange, when this problem occurs and I then have to turn the Sony unit off and back on to recover the sound, it's almost as if the unit has partially frozen up, as when I press the power button on the remote, the "standby" messages starts flashing on the LCD screen, as you would normally expect, but this message then persists for upwards of 2-3 minutes, and I'm unabl;e to turn the unit back on again until the message has disappeared!
I've got the box connected to the internet via a hardwired cable to my router, and as such I've run the software update function, the first time this actually applied some updates, the second it seimply told me that the software was 100% up to date, but I wasn't sure if this included the firmware as well, as I've read about some similar issues with Sony TV's being fixed by updating firmware.
Any answers/suggestions would be greatly appreciated, I'm a bit lost if I'm honest!  It isn't the end of the world, as I'm still able to watch regular definition channels fine, but I'd prefer to be able to watch the HD ones too, but having to switch everything off and back on every commercial break is just too much hastle!
3 REPLIES 3
matt0121
Visitor
Dear Sony,
I to am experiencing almost identical issues with the SONY BDVEF200. I have a Sony KDL-40CX523 40" LCD TV, a UK Virgin Media Tivo box and an Xbox 360 all connected via HDMI into the unit.
As per TehFuzz's issue when leaving any HD channel on the sound is muted when an advert break occurs and remains muted on all channels until the BDVEF200 is reset. Again similarly the system appears to crash and takes 2-3 minutes to turn itself off. This is particulaly annoying when watching Sky Sports HD which we pay an arm and a leg for and the sound mutes furing a game.
Having committed to a number of Sony products I am very dissapointed that other people seem to be experiencing this issue.
Sony please provide a fix or provide me a new box which works with HD channels when broadcast from a Tivo box.
Thanks,
Matt.
sibutler1
Visitor
I have the same problem (except the input is from a Humax Foxsat HDR). The problem doesn't occur on all HD programs. At the moment I think it only happens with Dolby Digital programmes. Otherwise the problem is as described by TehFuzz. How about a response Sony?
sibutler1
Visitor
After more experimentation I find I can avoid the problem by changing the surround sound audio setting on the Sony. By default this is set to "auto" - changing it to "2CH ST." (2-channel stereo) sorts it for me.
Obviously this is a fault in the BDVEF200 but this might help whilst Sony get round to fixing it.
