Rmt-d187p child lock problem
SOLVED
profile.country.en_GB.title
Millercrosses
Visitor
I went to take out a disk from my player after turning it on and it said "Tray Locked", I understand this is a child lock but it seems to have activated itself and I can't find my instructions.
So can anyone help?
Message was edited by: Millercrosses
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
Hi. Just give the callcentre a buzz - there is basically a standard code which unlocks the drive I think. They should be able to tell you over the phone.
Thanks
4 REPLIES 4
Bravia55HX
Member
if you believe the remote to be at fault you could try the re set,
remove the batteries,
press each button twice,
re install with fresh batteries.
Millercrosses
Visitor
I don't think it can be the remote since there's no eject button on it.
But thanks.
Catmambo
Contributor
Thanks
profile.country.IT.title
rooobb
Normally you can lock/unlock the tray and command by pressing the stop button on the deck till it says LOCKED/UNLOCKED
