BDV N7200W
webbymtb
Explorer
BDV N7200W
My N7200W system has frozen. Is stuck on 'BD/DVD'. I've tried resetting it (play/eject at the same time), but it does nothing.
I'm assuming this happened in the last week or so (I don't use it very often) and may be related to the latest firmware which was released a couple of weeks ago.
Any help with this will be greatly appreciated.
16 REPLIES 16
Pascale_F
Moderator
Hi webbymtb,
Welcome to the Community. I'm not too sure why it has frozen - perhaps you could get in touch with Sony Support about this.
Thanks,
Pascale
webbymtb
Explorer
I did get in contact with Sony Support, they gave me number of a shop to call. Quite useless, seeing as the shop is closed.
I'm now have a £470 paper weight.
webbymtb
Explorer
It's stuck on 'repeat play', if that helps?
Remote is still responsive, as are the function keys on the unit itself, but they don't do anything, if that makes sense?
The_Black_Rose
Specialist
Hi Webbymtb,
If you couldn't reset it then it needs physical inspection. I found a link for locating service cenres on Sony's website: https://bit.ly/2LRUI7u
Cheers,
The_Black_Rose
webbymtb
Explorer
Advising people to go to a service centre, while in lockdown?! Yeah, great idea.
Joe_Dohn
Specialist
I agree with The_Black_Rose, this would be for the best. But I believe you won't be able to get it inspected right now even if you wanted to since most service centres are closed for your safety (and of course, due to lockdown) but even if you manage to get in touch, maybe just tough it out for a bit. It's getting dangerous at the minute. Stay safe people!
alikho
Explorer
this happened to me also after firmware update, I used the latest update.
The_Black_Rose
Specialist
Hi Alikho,
Have you also tried resetting the player?
Cheers,
Rose
alikho
Explorer
Hi Rose,
I disconnected the AC power cord according to the manual and connected again but it did not help. Is there any other way to reset? I mean I almost went throw the hole manual
Cheers
Alan
