Question - recording md to cd ?
profile.country.en_GB.title
justkaz
can i connect my sony md player/recorder to a sony RCD-W100 cd recorder and record onto cd my md tracks please ? cheers non technical singer , Kaz.
profile.country.FR.title
ClarkLong
Hi Justkaz,
Of course you can. Just connect the "Line out" (mini jack) from the Md device to the "line in" (rca) of you RCD-W100. And then you're done. You can rec anything you want :slight_smile:
Which MD model do you have? I might be able to upload your recordings directly to your computer. :wink:
ClarkLong
Hi Justkaz,
Mickoz1974
I use optical connect out on one device to in on the other then do the same on the outer side so you have out to in and in to out. You can now record back and forth digitally with no copyright problems
