word wrap and images...
profile.country.nl_BE.title
dgoosens
hi,
I am very happy with my PRST1 except for two very very very very annoying issues and I wonder if someone has a solution for both of them.
1.
 word-wrap
As I do read quite a lot of programming books and articles, there quite often is code to be displayed.
This is coded between
 tags.
The problem is, when the lines get long, and although I added a CSS rule to the EPUB (pre { white-space: pre-wrap; }) the lines are not wrapped.
Hence I cannot read the end of the lines... Very annoying !
2.
Big images are not reduced so that they fit in the screen.
I did try to add a css rule for this (img { max-width:90%; }) but that did not change anything
I did read in some forums that these issues are related to the Adobe software used in the eReader...
I hope someone has a solution for these issues because it is really driving me nuts.
Thanks a lot in advance,
dGo
0 ANTWORTEN 0
