Sony RX100 firmware version?
profile.country.fr_CH.title
chbonin67
Visitor
How can I check the actual version of the firmware of my RX100?
Thanks.
Christian
Message was edited by: -Cass-
Edited for personal details
4 REPLIES 4
Thalamus.
Champion
Hi  chbonin67,
welcome to Questions & Answers..:smileyhappy:
Press the Menu button on the Rear of your camera to access the Menu screen..
Using the turning the control wheel select Set up menu & press the centre button..
Then again using the turning the control wheel select Version..
This should display your RX100 software version..
profile.country.fr_BE.title
Thudsyn
Visitor
This implies that Sony will release firmware update(s) for the RX100. Do you know when the first update will be released, which improvements it will implement, etc. ?
Thanks in advance.
KR
Thierry
cmosse
Contributor
There are no infos available regarding FW updates. Remind that RX100 is still brandnew and I do not know of any fw bug or other issues that need to be corrected by anujpdate yet. What kind of improvement would you like to see in an update?
Thudsyn
Visitor
No bugs as such, but the main point that I would like to see addressed is the sensitivity of the front wheel (needs to be turned way to much sometimes...). There are some discussions in other forum (e.g. dpreview) with (very long) wish lists of other users...
