dsc-wx9 problems
profile.country.ro_RO.title
paulneagu
Visitor
dsc-wx9 problems
  1. 1 cand inchid aparatul se blocheaza lentilele nu se mai retrag        2 butonul de zoom in-out se blocheaza pe zoom in        3 de multe ori imi spune ca nu se poate sa vad video pe ecran  adica ce filmez
3 REPLIES 3
profile.country.en_GB.title
blaireau_photo
Visitor
Hello paulneagu - Welcome to the Sony Forums :slight_smile:
Unfortunately you have posted on the English forums and your message is in Romanian. The Romanian Sony website doesn't currently have an online support community.
I have tried to read your message - are you having trouble getting the zoom lens to function correctly?
If possible, you could try editing your original message above and writing your question in English.
Thanks,
Simon
paulneagu
Visitor
1.   when  I close the device is no longer withdraw, lens block  2.   the  zoom button  in-out  locks wen i zoom in  mechanic .  3.   many times appears on display  can not play this file   can not see video on the screen just pictures.   These problems come and go.    SORY my sony is dsc-wx7
Message was edited by: paulneagu
Mick2011
New
Hi paulneagu :slight_smile:
It's not clear what the problem with the video playback is, but your main problem with the lens may need specialist repair.
You could try resetting the camera: switch it off, remove the battery, press and hold the shutter button for 30 seconds, replace the battery and switch on. If the problem persists, you should seek out a repair service in your country.
Cheers
Mick
