A problem with my camera
profile.country.bg_BG.title
sancho_bg
Visitor
Hello I have a little problem with my camera. It is a model Sony DSC-P12. The problem is that some time when I can not shoot me out of the image display and constantly hear a noise. I tried to RESET, but do not fix
2 REPLIES 2
profile.country.en_GB.title
Mick2011
New
Hi sancho_bg, welcome to the Sony Forums :slight_smile:
I'm not sure I understand the problem: is the camera not working when you press the shutter?
A constant noise is not normal with this model and probably indicates an internal fault, which is quite possibly related to the problem and which will need to be repaired at a service centre.
If you are in the UK you can register for a Sony-approved repair here or alternatively, ask at a local electronics repair centre for an estimated repair cost.
Cheers
Mick
sancho_bg
Visitor
The problem was identified and removed: gone spring band around the lens. I am from Bulgaria. Thanks anyway
