Flash failure
Langreano
Flash failure
The front and rear flash of my Xperia C4 does not work. Nor the lantern.
I am surprised that it is because the led has broken at the same time, both the front and the back.
Thank you
Langreano
The problem was solved. After two weeks ... one day the flash, the flashlight and the notification light started to work. I do not know why it stopped working ... or why it worked again.
