I have a XF9005 with sound going to aa Yamaha R-XV681 Receiver via ARC. The audio system only receives a signal from the tv when the audio output is set to PCM whereas I should be able to get a better sound signal than that.
Anyone had a similar problem? Any ideas.
Thanks
Hi
Which sources have you tried? What audio formats have you tried playing on the TV while testing other options than PCM?
Have you updated the TV: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xe80xx_x80xxe_xe83xx-series/kd-49xe8005/d...
Win_88
