Partilhe a sua experiência!
I'm now using the satellite input for tv rather than youview due to moving out into the welsh sticks!
When bringing up the TV guide it shows 'no event information' for all channels, only when you select and view a channel does it then pull through the tv guide info for that channel.
So you don't actually know whats on TV unless you scroll through all the channels one by one.
Anyone got any ideas or is this just buggy?
Thanks
Hi there,
Can you let me know the full model of your TV?
Best wishes,
Sean
It is a 43XE8004
Thanks
make sure its connected via LAN and it may populate guide i think you need to choose guide type ie freeview,in all fairness its still very slow despite latest Firmware update 27.11.2019
Can you tell me that you mean by 'choose guide type'? i can't find any option like this
thanks
Hi there,
When it comes to the functionality of the guide on satellite broadcast, your TV isn't fully compatible, so it may or may not work.
This isn't considered a fault with the TV.
Win_88
