Sony bravia KD75H93
Slysi11
Sony bravia KD75H93
Hi everyone just purchased a Sony bravia KD75XH92. and I have it set up to sky q but it won't let me put it on the 10 bit it is saying the TV won't support it any ideas 🤔
Slysi11
Just got 8 k hdmi cable and now it works fine thank you
3 ANTWORTEN 3
LightFoot
Spezialist
Hi @Slysi11
1. Are you connecting the Sky Q direct to the TV?
2. Are you using the Sky Q supplied short high speed HDMI lead?
3. Have you connected it into the Enhanced HDMI sockets (normally HDMI 2 or 3).
4. Have you turned on Enhanced 4K HDMI signal for the above ports? Note it tells you which ports are Enhanced when you turn it on. Settings -> Watch TV -> External inputs -> HDMI signal format.
Slysi11
Thanks for the reply. Just got a 8k hdmi cable and it works fine thank you
Slysi11
