No wifi when starting TV
parost
 It takes a few minutes until I have WIFI a my Sony Android TV.
Router is very nearby. I have tried both both DHCP and Static IP.
9 ANTWORTEN 9
Anonymous
Nicht anwendbar
Hi there
If the router is nearby - just use an ethernet cable and change network settings accordingly.  ?
Cheers
parost
I am not able to use a network cable.
What is causing this and how could it be solved. Sometimes I need to go to network settings and connecti to the network after turning on the TV.
chrisc383
I have the same issue. Up to 2-4 minutes before it comes online, in my case its on XD93. Fortunately, I was able to connect it via LAN port.
Anonymous
Nicht anwendbar
Hi there
Before I pass this onto Sony Support, can you:
  • Ensure that you have the latest firmware installed
  • Factory reset the TV
Besides, Sony will get you to do those two steps anyhow.  Also, you have not mentioned which model TV you have ?
For both @parost and @chrisc383 - What brand/model router do you have?  Just seeing if there are simularities.
Cheers
parost
I believe this is a generic problem.  I had the same problem with the previous TV (same model that went in to a boot loop and was exchanged).
I have made a factory reset and have the latest firmware.
TV: Sony KD-55XD8505
Router: Netgear R7000
chrisc383
In my case its Asus AC88 running stock firmware 3.0.0.4.380_4180, I was connecting using 5Ghz SSID, WPA2/AES. TV is XD93.
I had also a case when WiFi connected TV had LAN access, but no Internet access - reboot solved this, but seeing how long it takes to initialize WiFi connection, I switched back to Ethernet port.
Anonymous
Nicht anwendbar
Hi @parost
I have escalated your issue in this thread, as well as your other issue (HERE) to Sony Support.  Let us know how you get on.
Cheers
Anonymous
Nicht anwendbar
HI @parost
For some reason Sony cannot find any contact details on record.  Can you please send me a private message with at least an email address and ill forward it to Sony.
If you are not happy to do so, please contact Sony via:
http://services.sony.co.uk/supportmvc/en/Contact/Email
Cheers
parost
It happened again. I needed to remove the tv device from Google Home and uninstall the cast app from the TV...
