Led strip light message -High voltage please disconnect USB
Carolm04
Hi
I have a Sony Bravia tv and bought some led strip lights to provide some ambient lighting.  Unfortunately when I plug them in to the usb outlet I get an error message advising me to unplug them due to a power issue.  I believe they may be 5w output (I’m not technical in the slightest) and “think” the usb output might only be 2.5 but I may be wrong.  Any suggestions?  Or ideas where I can get lights that will work on the KD-55XF8096?
thanks
IamNic
Hello @Carolm04,
you can check the power draw with little USB-Power-meters (cost less than 10bucks). I assume the lightstrip you got usually needs to be used together with a wall-plug that delivers more power than the port on the TV.
I personally would keep the current LED strip and get a remote controlled wall-plug to use with a USB-wall-adapter. Then you can even power the light on and off independand from the TV.
