KDL-65W855C Replacemant Pedestal Stand
Hi - i am trying to find a replacement for the KDL-65W855C stand as mine has been wall mounted since i bought it and accidently through the stand out. I went to the http://uk.eetgroup.com/Guide/m/Sony-LCD-Television-55-inch-KDL-65W855C page but it's not clear which is the stand. Thanks for your help.
1 REPLY 1
Anonymous
Not applicable
Hi there
Did you use the wall mount supplied with the TV, as it has a duel use of a wall mount or tabletop stand.  If not, and you threw it out, you may need:
http://uk.eetgroup.com/i/454688901-Sony-Stand-Pipe-2L-EGL-A
Probably require http://uk.eetgroup.com/i/454691001-Sony-Stand-Neck-Assy  which is an attachment that connects the tv to the stand.  Maybe a bag of screws too: http://uk.eetgroup.com/i/456275801-Sony-Bag-Screw-A-Egl
Although, if you need the lot, it might be cheaper for a VESA table stand instead.
Cheers
