Hello,
I compared KD55X8509C with KD55X8505C and to my surprise found that the 8505 is a little newer and has a better spec. ie 10-bit addressing and SMB
http://www.lcd-compare.com/index.php?action=compare&SONKD55X8509C=on&SONKD55X8505C=on
Is this true? Or is it just a web site error?
Thanks
Solved! Go to Solution.
In that case, does Sony have a TV with native 10-bit display panel?
Not at the moment, but Sony have Triluminos Display with 10-bit processing for a wider color gamut.
Manolo
