KD-55AF8 TV overloads when exiting standby mode.
profile.country.IL.title
Redba71
KD-55AF8 TV overloads when exiting standby mode.After updating to the latest firmware. This happens when the TV exits standby mode. Mostly in the morning. Sonos  Beam  is connected in HDMI ARC 3.How to solve a problem?. All the methods from the forum did not help.
5 ANTWORTEN 5
Does it happen too if you disconnect all devices?
Cheers
Redba71
No.
Win_88
Spezialist
Hi @Redba71
What do you mean by it overloads? what are the external devices you usually use with the TV that when removed, the situation improved?
Win_88
Redba71
In the morning, from standby mode, it immediately turns on for a few seconds and then restarts. Sonosus is connected. If I turn it off, then in the morning everything works fine without rebooting.
Win_88
Spezialist
Hi @Redba71
That's odd. I'd suggest going to Settings - External inputs - Bravia Sync - Off, unplug everything from the mains for a minute then once everything is back up again, test the TV with the Sonos connected.
Do you turn the TV on usually with the Sony or Sonos remote?
Win_88
