Infinite initial setup loop
SOLVED
aoriol
Member
Hello,
My 4K Sony (model KD-55X8005C) is stuck on the initial setup screen and goes back to the Welcome (the screen where you're asked to pick a language) screen in an infinite loop after choosing any of the two options on the Location (the screen where it asks you whether you want to share the location with Google) screen after I did a settings reset.
I've googled this issue and found many people who have experienced the same exact issue (see https://www.youtube.com/watch?v=zf9JFNk_ju0 & https://community.sony.com/t5/4K-Ultra-HD-TV/Stuck-with-initial-setup-screens-on-my-Sony-Bravia-4k-A... & https://www.reddit.com/r/AndroidTV/comments/45sw8t/sony_android_tv_saferecovery_mode/).
I have tried factory resetting the device (holding down the power button on the TV together with the up arrow on the remote control), installing a fresh firmware via a USB drive (it told me the firmware is already up to date and I couldn't find a way to force it to continue) but nothing seemed to work!
Is there a solution to this bug?
I bought this TV model KD65X8500C 2 days ago. After a new software update (PKG2.587.0017PAB), I did a Initial Setup once more because of this error message "google play service stopped unexpectedly" message came out often. This is when the nightmare began. Everything I tried to do the setup ...
97 REPLIES 97
profile.country.GR.title
MiCal1967
Contributor
If apps are running OK in background, then your wired network must be OK too for ADB commands.
aoriol
Member
Paging @angelacr, @cozzykim, @Kevin8098, perhaps you guys can help me out with some advice? 😞
Long story short, the TV entered a boot loop similar to this after a factory reset. One caveat is that I purchased the set in the UK and did the reset in a different country...
angelacr
Member
http://forum.xda-developers.com/nexus-player/general/sony-android-tv-users-t3096901/page13 see posts by croques. You will need to have enabled adb previously. Note the advice about the USB cable it will only work with the cable described.
aoriol
Member
@angelacr, thanks for the reply. I remember having the developer mode on, however I don't remember switching the ADB debugging option on unfortunately. I tried connecting via a male to male USB but failed - the adb devices list is empty 😞
@pikachu2, if ADB debugging is off, does it mean I'm f-ed? Would a new firmware version (whenever it comes out) solve the issue?
angelacr
Member
I can't stress enough how important it is to have the right USB cable!  Male to male, yes of course, but it MUST be straight through rather than cross-over or even just a power cable. It needs 4 wires. You need to check with a continuity meter that the pinouts on the connectors correspond. Search for a USB pinout diagram and double check that data + is connected to data + and that data - is connected to data -.
I cannot belieive that Sony would leave a their TVs unbootable to the bootloader. On an android phone we usually hold a key combo from the phone off condition. Usually power and volume down - held until the phone boots.
But if all else fails yu need a visit from the Sony repair man.
aoriol
Member
@angelacr I'm pretty sure the USB cable is good. Will try another one shortly.
Same here - super disappointed 😞 I hope the key combo is out there, it's just that it's not public. Perhaps someone from Sony could help me out?
angelacr
Member
@aoriol
You really need to be sure. A straight through cable is very unusual; typically used on USB hard drives. Best put a meter on it to check or if all else fails and you don't fancy a trip to the computer shop, use lash-up of a battery, wires and a torch bulb. When you know the cable is good,, only then can you have a definitive answer.
MiCal1967
Contributor
@angelacr @aoriol
The best way to check if cable is OK, is to test on another Android device. You can use the micro USB to USB Female OTG, that is usually provided with phones or tablets, in combination with your Male to Male USB.
Try another Android device with Developer Option Enabled to be 100% sure.
Did you also try with a Windows PC ?
angelacr
Member
@MiCal1967
Useful contribution.
MiCal1967
Contributor
@aoriol
Did you use Netflix before leaving U.K. ?
