How to set sky box as default output on KD49-X8309c
rikksow
Explorer
Hi does anyone know how i can make my tv button default to my HDMI 1 socket rather than the digital freeview on the tv. When i press the tv button on the remote control it brings up the freeview built into the tv but i wish for it to defaul to my sky box as this is how i watch my tv
1 REPLY 1
philjwade
Member
Have you set your Sky Box to have HDMI Control switched on? If you have paired your Sky remote to the TV then just pressing the Sky button i.e. switching on your Sky box should switch on your TV directly to view Sky via the HDMI port you are plugged into. Also enable Bravia Sync on your TV. Check out the Sky help site http://help.sky.com/articles/hdmi-one-touch-play
