Home Theatre Control 55xh9005 and htg700
jutler123
Member
Hi all
Just wanted to know if anyone here can answer this.  There is an option in the display and sound menu under audio output called home theatre control.  I have a htg700 connected via hdmi to my tv but when I go into that option, I get a message saying "Home Theatre Control" only works with these audio systems... And gives me a list of audio systems.  However the htg700 is not part of this list but older models, such as the htxf9000 is.  Is this something that will be available in future updates? Is it just a case of waiting for sony to update the software? What kind of features does home theatre control provide?
Thanks for any responses in advanced
3 REPLIES 3
Joe_Dohn
Specialist
I believe it allows you to control the settings of the Home Theatre system settings. Though, I have no idea if this would be supported on the G700 in the future/via an update.
I did pass it along to Sony as feedback via email so you don't have to. ^^
- JD
jutler123
Member
Thanks Joe_Dohn
It's a shame if not supported by the G700, as it seems older models like XF9000 which i believe is the equivalent?
Joe_Dohn
Specialist
It's not quite equivalent but you can check the specifications comparison for more info.
