Firmware bugs for KD-49X8005C
KristianPopov
Explorer
Hi, after update firmware with V.3.155, my TV Optical output is stoped play 6 chanel audio(only 2 chanels).I probe with new version 3.169 and problem is the same...Can i Downgrade the firmware with V.2...?I make Hard Reset the settings and nothing...And What can i do???
2 REPLIES 2
Anonymous
Not applicable
Hi there
As there has been a couple of firmware updates since, it is most likely your issue has gone away now.  Are you able to confirm if its working again?
Cheers
Normis83
Explorer
You will find lots of videos related to it on YouTube, just check them and you will find lots of videos to resolve your issue.
