Sony Summer Cashback
gamagee89
hi, wonder if anyone can help, trying to get my cashback on the summer promotion, i filled everything in correctly but when i upload my proof of reciept and camera serial number i get the following, see pictures, can anyone tell me what is wrong, the files im uploading are jpegsthe message i recievethe message i recievemy uploadsmy uploads
6 ANTWORTEN 6
deze70
Hope this helps
gamagee89
first of all, thank you for the reply, i downloaded the images off my iphone, no matter what i do i cant get rid of all the writing, i rename the file .jpg and when i upload it to the apllication for it says jpeg.jpg and still knocks me back. could you explain hown you would do it please
gamagee89
is this what you mean my friend because it still gives me the same messageScreenshot (19).png
deze70
Firstly, make sure you can see extensions in windows.
Open Control Panel > Appearance and Personalization.  Now, click on Folder Options or File Explorer Option, as it is now called > View tab. In this tab, under Advanced Settings, you will see the option Hide extensions for known file types. Uncheck this option and click on Apply and OK.
show file extensions
Then:
Just rename your files to something like:  invoice.jpg   & serial.jpg
Hope that helps
Deze
gamagee89
aw m8, i really appreciate your help, i did everything you said, all went well, pressed confirm and i got the error message again, il show pics below, forget about the middle photo, both file names were changed to what you said, its doing my head in but i do thank you for your helpScreenshot (20).pngScreenshot (21).pngScreenshot (22).png
deze70
I see in your properties window that the files may be blocked? Try ticking unblock and apply on both photos.
Close properties, Then try and change the extensions from .jpeg to .jpg in exporer.
It's kind of hard for me to duplicate your results as i'm on a mac here.
