- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Using the navigation software gps does not work.
I used navigation once in a while, no problem. After that, it has been useless. I suddenly found out that the navigation software can be positioned in the past two days, but the GPS signal is weak during the navigation process, and it does not work at all. It is useless to refresh the navigation. Exiting the navigation can also locate [question] Have you encountered this situation? All permissions are open. Baidu maps and Gaode maps have the same effect and cannot be used. Was it a problem after the last system update?
使用导航软件gps不工作的问题。
前段时间用过一次导航,没有问题。之后一直没用,这两天突然发现,一进导航软件可以定位,但是导航行驶过程中就提示gps信号弱,根本不工作,点刷新导航也没用。退出导航又可以定位了[疑问]有没有遇到我这种情况的?所有权限都开了。百度地图和高德地图效果一样,都不能用。是上次系统更新后出现的问题吗?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I haven't noticed any issues with the GPS, are you in a city with a lot of skyscrapers that might be blocking it? Does the phone has a protective case?
