VPCJ12M0E Update Issues [Vaio care recovery + Rescue Data]
SOLVED
Volksdevil
Explorer
Hi, I have a VPCJ12M0E Desktop and Vaio care has just popped up with two updates:
Vaio care recovery - 31/3/2014 30267KB
Rescue Data(x86) Update Program 24/2/2014 22468KB
When I click update, I get:
Installation failed
Please wait a while, then try again.
And further still, when I click the links to the updates listed above I get the following pages respectively (404 not found!)
http://support.vaio.sony.eu/computing/vaio/downloads/info/en/EP0000321150.xml
http://support.vaio.sony.eu/computing/vaio/downloads/info/en/EP0000320626.xml
Can anybody please help? I had an issue like this before with an update that never seemed to get resolved, something to do with nividia graphics driver or something.
Neil.
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi Volksdevil,
This problem effects serveral models but if you try the direct download it should install.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000321150_9606/VPCJ12M0E
Rich
Go n-éirí an bóthar leat
12 REPLIES 12
Volksdevil
Explorer
Update:
I tried updating Vaio care recovery on it's own, which didn't work.
So I then tried updating Rescue Data(x86) Update Program on it's own, and that updated just fine.
So now I'm left with just the one update which still gives the same error:
Installation failed
Please help.
Neil.
Volksdevil
Explorer
Still having this issue.
Drewde
Administrator
Hi @Volksdevil
Can you please PM me your VAIO serial number, email address, contact phone number and a screenshot of the error message displaying the website link and the error message.
Thanks,
Drew
Volksdevil
Explorer
Done, pm sent.
Drewde
Administrator
Thanks.
rich912
Contributor
Hi Volksdevil,
Rich
Volksdevil
Explorer
That seems to have done the trick thank you, although I'd hope that VaioCare itself can take care of this in the future.
EDIT: Can I safely remove the download from my PC after having done the update? I like to keep it as clean as possible.
rich912
Contributor
Hi volksdevil,
There have been problems with Vaio Update and Vaio Care for many years, so although the applications should take care of updates if you do encounter problems then it is always worth investigating a direct download from the support site.
Yes you can safely remove the downloaded file once installed.
Rich
Volksdevil
Explorer
Hi Rich, I don't see anything in your reply there?
