i have a VGN-Z11WN, with the wide screen, and a problem with font size. if i set it to default (96dpi) it is too small to work with. if i set it to 120 some websites and programmes display too large and forms are not functional as the text spills over the box space. even set to 120, some websites come up as too small to comfortably read, and i find i have to constantly be clicking on the 'change zoom level' adjuster when surfing. what is the solution? thanks
Hi TLA,
welcome to Club VAIO..
Have you tried adjusting the screen resolution.?
To change the screen resolution click on Start, followed by Control Panel.
In the Control Panel window under the Appearance and Personalisation heading click on Adjust screen resolution.
