PROBLEM WITH FONT SIZE
TLA
Visitor
I posted on here yesterday and don't see it showing, so I am re-posting.
I have a VGN-Z11WN, with a wide screen, and a problem with font size. If I set it to default (96dpi) it is too small to work with. If I set it to 120 some websites and programmes display too large and forms are not functional as the text spills over the box space. Even set to 120, some websites come up as too small to comfortably read, and I find I have to constantly be clicking on the 'change zoom level' adjuster when surfing.
What is the solution? Or if you don't know the solution, can you point me towards some other support source that would be able to help? Preferably one that doesn't cost a fortune to phone.
Thanks.
1 REPLY 1
Thalamus.
Champion
Hi TLA,
welcome to Club VAIO.. :slight_smile:
I had replied to your other thread (here )
Have you tried adjusting the screen resolution.?
To change the screen resolution click on Start, followed by Control Panel.
In the Control Panel window under the Appearance and Personalisation heading click on Adjust screen resolution.
