Please help me.
urOk
Visitor
Please help me.
I would like to turn off touch pad cos i use a mouse but have no idea where is this option if exists. My model sony is FZ21M. Thank you for all help in advance.
3 REPLIES 3
Thalamus.
Champion
Hi urOk,
try this..
Press the windows key+R to open the Run box then type C:\Program Files\Sony\Setting Utility Series\VCCPointingDevice.exe
Click Continue on the UAC window
A Pointing device window should appear that should allow you to either enable or disable your touchpad..
If this works, you can place a shortcut to VCCPointingDevice.exe onto your desktop..
I have included a guide on the process should you wish to create a shortcut..
1. Right-click an open area on the desktop, point to New, and then click Shortcut.
2. Click Browse.
3. Goto C:\Program Files\Sony\Setting Utility Series and then select VCCPointingDevice.exe from the list of files, then click OK and then click Next.
4. Rename the shortcut to something more use friendly and click Finish.
urOk
Visitor
Hi Thalamus.
Thank you so much for your help. I did all what you said, working perfect!
Once again thank you, and have a great day :slight_smile:
Thalamus.
Champion
You're welcome urOk.. :slight_smile:
