DVP-NS718H Child lock problem
profile.country.en_GB.title
Millercrosses
Visitor
I went to take out a disk from my player after turning it on and it said "Tray Locked", I understand this is a child lock but it seems to have activated itself and I can't find my instructions.
So can anyone help?
6 REPLIES 6
Bravia55HX
Member
on the remote, press return, enter, then on.
that should unlock it.
let me know if you would like a PDF instruction manual for it.
Millercrosses
Visitor
I've done this as you said, but nothing happened. Unless i've read it wrong, do I keep the player off? Do I have to hold any of the buttons?
Bravia55HX
Member
press the buttons in the sequence given with the player in standby mode,sorry i was not clear, i'll give you the link to the PDF manual, save it in bookmarks for future reference. page 8 under settings and adjustments.
http://pdf.crse.com/manuals/4139513111.pdf
Message was edited by: Bravia55HX923
Message was edited by: Bravia55HX923 error in message
Bravia55HX
Member
if it does not work in sequence then hold all three down together!
Millercrosses
Visitor
It's just not doing anything at all.
Bravia55HX
Member
how odd!, ok if you followed insructions theres only a couple of things left to try and at this point i'm fishing, unplug the machine and leave a little while, put some fresh batteries in the remote, (the old ones might be tired), plug it back in and try again, to be honest the tray lock/unlock should work with the instructions given.
